DEPRECATION
Shapefile Network Dataset Deprecation Notice
ArcGIS Pro 3.2 will be the last release that supports the shapefile network dataset as a valid file type. ArcGIS Pro has never supported the ability to create or edit a shapefile network dataset. ArcGIS Enterprise has never supported the publishing of services from shapefile network datasets.
Recommendation
At the next ArcGIS Pro release, the shapefile network dataset will not be recognized as a valid file type and will not be displayed in the Catalog pane or dialogs for supported file types. Esri recommends all customers to prepare for this change by building their network datasets in a file geodatabase or enterprise geodatabase. Models and scripts that reference shapefile network datasets must be migrated to use network datasets in a file geodatabase or enterprise geodatabase.
•  Use the Feature Class To Feature Class tool to migrate the shapefile network data sources to a file geodatabase.
•  The Create a network dataset tutorial guides users through creating a network dataset inside a file geodatabase.
Article ID:000030973
Software:
  • ArcGIS Pro
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
