DEPRECATION
Imagery World 2D and StreetMap World 2D Basemaps
Last Published: May 3, 2024
Esri is retiring two very old raster basemaps on May 4, 2022. If you are using one of these basemaps, Esri advises switching to the equivalent basemap in general availability.
Once these basemaps are retired, they will no longer be available to use in maps and apps.
Retired basemapReplacement basemap
ESRI_Imagery_World_2DWorld_Imagery_WGS84
ESRI_StreetMap_World_2DWorld Street Map (WGS84)
ArcMap users will need to use World_Street_Map as a replacement, but note that this basemap is in Web Mercator.
The 2D basemaps were placed in mature support in 2016 and have not been updated. The replacement basemaps are updated regularly and have more worldwide coverage.
Recommendation
ArcGIS Online users:
If you are the owner of a web map in ArcGIS Online, the easiest way to migrate to the newer version is to copy the URL listed below and add the basemap in the Map Viewer using the Add tile layer option.  If you are unsure what basemap you are using in your web map, go to the item details page for the web map and look for the basemap in the Layers list.
Replacement basemapURL to add to Map Viewer
World_Imagery_WGS84https://wi.maptiles.arcgis.com/arcgis/rest/services/World_Imagery/MapServer
World Street Map (WGS84)https://basemaps.arcgis.com/arcgis/rest/services/World_Basemap_GCS_v2/VectorTileServer
ArcGIS Pro users:
Migrate to the newer version by copying the URL listed above in the ArcGIS Online section, and use Add data from a path
ArcMap users:
Migrate to the newer version by copying one of the URLs below and add to ArcMap.
Replacement basemapURL to add to ArcMap
World_Street_Map (Web Mercator)https://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer
Developers:
Reference the REST endpoints listed above in the ArcGIS Online section.
Article ID:000027382
Software:
  • ArcMap
  • Developer
  • ArcGIS Pro
  • ArcGIS Online
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
