DEPRECATION
ArcGIS Notebooks runtime versions 8 and 9
First Published: March 16, 2026
Last Published: July 3, 2026
ArcGIS Notebooks runtime versions 8 and 9 have been retired since June 2025 and October 2025 respectively and were removed with the June 2026 update of ArcGIS Online.
Recommendation
To avoid workflow disruptions, ArcGIS Notebooks users must take the following steps by June 2026:
  1. Review runtime version
    • Go to the Notebooks home page and check the runtime version for each notebook under "My notebooks" or "Shared notebooks". A red triangular caution sign indicates a retired runtime.
  2. Review and choose compatible runtime
    • Review the available Python libraries and their compatibility with different runtime versions.
    • Choose a runtime version that is compatible with your code, considering library availability and compatibility.
  3. Update runtime version
    • From the Notebooks homepage, select the notebook items to update and click "Update runtimeā€.
    • Alternatively, open the notebook's item page and navigate to the Settings tab.
    • Select the latest runtime version compatible with your code from the drop-down list.
  4. Test the notebook
    • After updating the runtime version, test your notebook to ensure it works as expected.
    • If the notebook has been published as a web tool, overwrite the web tool to update the runtime associated with it.
Article ID: 000040654
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
