DEPRECATION
ArcGIS Notebooks Runtime v6 and v7
Last Published: November 3, 2025
ArcGIS Notebooks Runtime versions 6 and 7 have been deprecated for over a year and will be removed with the ArcGIS Online Q1 2026 update.
Recommendation
To avoid workflow disruptions, ensure ArcGIS Notebooks users take the following steps by February 2026:
Step 1: Review Runtime version
Go to your Notebooks homepage and check the Runtime version for each notebook under "My notebooks" or "Shared notebooks." A triangular caution sign indicates a deprecated Runtime.
Step 2: Review and choose compatible Runtime
Review the available Python libraries and their compatibility with different Runtime versions.
Choose a Runtime version that is compatible with your code, considering library availability and compatibility.
Step 3: Update Runtime version
Open the notebook's item page and navigate to the Settings tab.
Select the latest Runtime version compatible with your code from the drop-down list.
Step 4: Test your notebook
After updating the Runtime version, test your notebook to ensure it works as expected.
Article ID: 000038615
Software:
  • ArcGIS Online
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
