DEPRECATION
The ArcGIS Runtime Utility Network Extension license is deprecated. This license enables trace analysis operations on a utility network. The last release of the ArcGIS Maps SDKs for Native Apps to include support for this license extension was version 200.3, which was launched in December 2023. In the next release, 200.4, all functionality previously enabled by this extension license will be available with an ArcGIS Runtime Lite license.
The ArcGIS Runtime Utility license was required for trace operations on an ArcGIS Utility Network in the following scenarios:
The deprecation impacts the following products and versions:
Customers using an ArcGIS Runtime Utility Network Extension license in their application and are planning to update to version 200.4 (or later) of ArcGIS Maps SDKs for Native Apps can modify their code by removing the extension license string from the ArcGISRuntimeEnvironment.SetLicense() method/function call. The exact syntax will depend on the SDK and language used.
Article ID: 000032489
Get help from ArcGIS experts
Start chatting now
