DEPRECATION
ArcGIS Insights
Last Published: October 24, 2025
ArcGIS Insights is retiring. Here are the key dates to keep in mind:
  • The last version of ArcGIS Insights for ArcGIS Enterprise will be released in Q2 2025. Customers will no longer be able to access the site or product with ArcGIS Enterprise 12.0 or beyond.
  • The last version of ArcGIS Insights for ArcGIS Online will be released in Q2 2025. Customers will no longer be able to access the site or product after the Q2 2026 ArcGIS Online update.
  • The final retirement of ArcGIS Insights is scheduled for June 2026.
Recommendation
Customers must assess their ArcGIS Insights workflows and datasets to determine the best migration plan based on their required functionality. Equivalent capabilities are offered through several ArcGIS products, such as ArcGIS AllSource, ArcGIS Dashboards, ArcGIS Data Pipelines, ArcGIS for Power BI, ArcGIS Knowledge, ArcGIS for Microsoft 365, ArcGIS Notebooks, and ArcGIS Pro. This guide can assist customers in identifying the product that best meets their needs to complete their essential workflows.
Use CaseRecommended Product for Migration Consideration
Interactive charting, visualization, & dashboarding 
ArcGIS Dashboards - Dashboards for basic series charts and tables that interact with maps 
ArcGIS AllSource for link analysis 
Map Viewer (ArcGIS Online and ArcGIS Enterprise) for map visualizations and charts  
ArcGIS Experience Builder for no-code data visualizations
Analyze data directly in your source RDBMS database or data warehouse
ArcGIS GeoAnalytics Engine
  • Enables analysis directly within cloud architecture, allowing spatial analysis of data without the need to replicate it
  • Users are required to set up the Apache Spark environment to handle distributed analysis.
ArcGIS Pro
  • ArcGIS Pro tools that can leverage the database, or the feature service API include:
  • Select Layer by Attribute
  • Select Layer by Location (using Intersect DBMS relationship)
  • Append (with Online hosted feature service as the target)
  • Calculate Field (using SQL expression)
  • Summary Statistics (using DBMS statistics)
  • Truncate
  • Make the connection in ArcGIS Pro
ETL data from a RDBMS or data warehouse, then work with that data in ArcGIS 
ArcGIS Data Interoperability (an ArcGIS Pro extension)
Reporting and sharing (analysis of results as well as reproducible workflow) 
ModelBuilder in ArcGIS Online & ArcGIS Pro 
ArcGIS Notebooks 
Explore spatial & non-spatial relationships with graph databases and link analysis 
ArcGIS AllSource 
ArcGIS Knowledge 
Map analysis tools The MapViewer (in ArcGIS Online and ArcGIS Enterprise) 
Perform data analysis workflows with both spatial and non-spatial data
ArcGIS for Microsoft (ArcGIS for Power BI, Connectors for Power Automate, ArcGIS for Excel, ArcGIS for Microsoft Fabric) 
ArcGIS Business Analyst
ArcGIS AllSource
Solution-based business data analysis 
Data engineering (data prep)
ArcGIS Pro 
ArcGIS Connectors for Power Automate
Python and R Scripting
ArcGIS Notebooks
R-ArcGIS Bridge (ArcGIS Pro integration)
Connections to cloud data One Drive and SharePointNot supported in ArcGIS
Article ID: 000034240
Software:
  • ArcGIS Insights
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
