HOW TO
Deploy the Hazard Reporting Collector Solution to Portal for ArcGIS
Summary
The Hazard Reporting Collector, one of the solutions available in the ArcGIS Solutions Deployment Tool, generates two items: a feature layer and a web map in the active portal (Portal for ArcGIS or ArcGIS Online). There may be rare cases, when loading the associated feature layer the portal map viewer, when one sees the following error:
Error
The layer, [layer name] cannot be added to the map.
This has number of potential causes, including (but not limited to):
  • The availability of the service
  • The size of the content
Procedure
This procedure outlines the steps to deploy the Hazard Reporting Collector solution to Portal for ArcGIS:
  1. Ensure you have the latest version of ArcGIS Pro, or another version that is compatible with the ArcGIS Solutions Deployment Tool. For more information, see the Requirements  section of the ArcGIS Solution Deployment Tool documentation.
  2. If the ArcGIS Solutions Deployment Tool is not already installed, install it by following this link.
  3. Launch ArcGIS Pro and set the active portal.
  4. On the Share tab, click ArcGIS Solutions Deployment then select Deploy an ArcGIS Solution.
  1. Click Electric > Hazard Collection, then click Deploy.
  2. Once the solution deploys successfully, click the green check mark to view the solution in your organization's content. The layer loads in the web map.
Article ID: 000023996
Software:
  • ArcGIS Solutions
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
