Summary
Instructions provided describe the procedure for finding and deleting dangling arcs from a polygon layer.
Procedure
- Create an empty checked-out coverage from the ArcStorm layer containing the dangles.
Arcedit: edit canada.nova.parcel polygon
Arcedit: show number selected
Arcedit: checkout emptycov
Executing CHECKOUT request...
Checked out 0 features into E:\EMPTYCOV with ID 21
- Display the ArcStorm layer as a back coverage and add a polygon to the empty checkout coverage which surrounds the dangling arc.
Arcedit: edit emptycov polygon
Arcedit: drawenvironment polygon
Arcedit: backcoverage .parcel 3
CANADA.NOVA.PARCEL is now background coverage 1 with draw symbol 3
Arcedit: backenvironment arc
Arcedit: draw
Arcedit: editboundaryerror polygon warn
Arcedit: add
--------------------Options--------------------
1) Add Polygon 2) End Polygon 4) Delete last point
5) Delete last Polygon 8) Digitizing Options 9) Quit
(Polygon) User-ID: 1 Define the polygon
Adding polygon 1 with 7 points
Polygon exceeds current edit boundary of local ARCSTORM coverage
1 polygon(s) added to E:\EMPTYCOV
Arcedit: save
The ArcStorm layer (in green) is the back coverage. The new polygon (in yellow) is added to the empty check out coverage and must completely encircle the dangling arc.
![[O] Addpoly image](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000002011/00N39000003LL2C-0EM39000000wcPy.png)
- Check the new polygon feature in, and immediately select the same feature and check it out again. The dangling arc will be checked out with the surrounding polygon.
Arcedit: resume emptycov
Arcedit: checkin
Arcedit: selectmode library
Arcedit: draw
Arcedit: editfeature polygon
Arcedit: select
Point to the feature to select
Enter point
Selected library feature 29
CANADA.NOVA.PARCEL polys : 1 selected.
Arcedit: checkout danglecov
- Delete the checked-out polygon and check the coverage in again. The dangling arc will be removed from the universal polygon.
Arcedit: selectmode edit
Arcedit: select all
Arcedit: delete
Arcedit: save
Arcedit: checkin
