HOW TO
Delete annotations stored in a map document in ArcMap
Summary
Instructions provided describe how to delete annotations stored in a map document in ArcMap.
Procedure
There are two ways to delete annotations from a map document:
  • Use the Select Elements tool to select the desired annotation:
  1. Click the annotation to be deleted.
  2. Press the Delete key on the keyboard.
  • Remove the annotation from the Annotation Groups tab in Data Frame Properties window:
  1. In the ArcMap menu, click View.
  2. Select Data Frame Properties.
  3. Click the Annotation Groups tab.
  4. Select the annotations to be deleted.
  5. Click Remove Group.
Article ID: 000012429
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
