PROBLEM
Default selections are unsupported after upgrading Esri Maps for SAP BusinessObjects
Dashboards created using Esri Maps 1.0 for SAP BusinessObjects do not display default selections on the map when the add-on is upgraded to version 2.0.
Cause
The implementation of default selections improved in Esri Maps 2.0 for SAP BusinessObjects. As a result, after upgrading the Esri Maps for SAP BusinessObjects add-on from version 1.0 to 2.0, dashboards created at 1.0 no longer display configured default selections on the map in consumer mode.
Solution or Workaround
Dashboard designers must follow the solution provided below.
  1. In SAP Dashboards with the Esri Maps 2.0 add-on deployed, open the dashboard.
  2. From the SAP Dashboards menu, click File > Save to Platform > Desktop Only to save the dashboard to the Business Intelligence (BI) Platform.
    Alternatively, click File > Export > HTML to publish the dashboard in HTML format.
  3. Open the updated dashboard in BI Launch Pad or in the web browser.
  4. If required, log in to ArcGIS using valid credentials.
Article ID: 000012376
Software:
  • Legacy Products
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
