ERROR
Datums do not share a common transformation
Error Message
Projecting between NADCON datums and Three or Seven Parameter datums returns the following error:
"Datums do not share a common transformation."
Cause
PROJECT supports two types of datum transformation: equation-based and grid-based. The best way to convert between NAD27 and NAD83 is to use a grid based method called NADCON. Other datums, like WGS84, use equation-based methods. The PROJECT command cannot fix and match datums that use these two different transformation methods.
Solution or Workaround
  • Projecting from NAD27 to WGS72:
    1. PROJECT the NAD27 coverage to NAD83.
    2. Use PROJECTDEFINE to change the NAD83 coverage DATUM specification to the NADCON-equivalent equation-based datum such as NAR_C.
    PROJECTDEFINE COVER cov_nad83
    PROJECTION <projection_name>
    UNITS <units>
    DATUM NAR_C
    PARAMETERS
    3. PROJECT the coverage with the NADCON-equivalent datum to WGS84.
    PROJECT COVER cov_nar_c cov_wgs84 filename.prj
    Contents of filename.prj:
    INPUT
    UNITS <units>
    DATUM NAR_C
    PARAMETERS
    OUTPUT
    UNITS <units>
    DATUM WGS84
    PARAMETERS
    END
    4. PROJECT the WGS84 coverage to WGS72.
  • Projecting from WGS72 to NAD27:
    1. PROJECT the WGS72 coverage to WGS84.
    2. PROJECT the WGS84 coverage to the NADCON-equivalent equation-based datum, such as NAR_C.
    PROJECT COVER cov_wgs84 cov_nar_c filename2.prj
    Contents of filename2.prj:
    INPUT
    UNITS <units>
    DATUM WGS84
    PARAMETERS
    OUTPUT
    UNITS <units>
    DATUM NAR_C
    PARAMETERS
    END
    3. Use PROJECTDEFINE to change the NADCON-equivalent datum name to NAD83.
    PROJECTDEFINE COVER input_cover
    UNITS <units>
    DATUM NAD83
    PARAMETERS
    4. PROJECT the NAD83 coverage to NAD27.
    The NADCON equivalent datums, such as NAR_C, are approximations of NAD83 or NAD27. To find the NADCON equivalent keywords see the ArcInfo Help topic 'Supported datums in PROJECT'.
  • If the WGS84 data is not very accurate, use PROJECTDEFINE to convert directly to NAD83.
    UNITS <units>
    DATUM NAD83
    PARAMETERS
    Although these are the most accurate methods to PROJECT between the two datum types, the distortion of any data set compounds after each projection.
Article ID:000002373
Software:
  • Legacy Products
  • ArcMap 8 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
