BUG
Attempting to display a Java Viewer site, that is based on a Feature Service with 2 or more shapefiles the following error occurs:
"Data cannot be found."
The display of layers changes intermittently and it appears there is a problem with data access.
There are no problems using the same map configuration file (.axl) with an Image Service, or the same data in an .mxd based ArcMap Service. These services display as expected in a Java Viewer.
J2RE 1.4.0 does not display all data on some computers.
Article ID:000006615
Get help from ArcGIS experts
Download the Esri Support App
