PROBLEM
Data Interoperability 2022.0 and above fails if Python switches Character Encoding from UTF-8 to windows-1252
Last Published: April 15, 2024
When using ArcGIS Data Interoperability and FME version 2022.2.1.0 and above, in some cases character encoding is switched from UTF-8 to windows-1252.  If this occurs, the Data Interoperability or FME process fails. The following is an example of text from a LOG file indicating the problem.
OS Locale Name     : en_AU
OS Locale Encoding : windows-1252
Process Encoding   : UTF-8
C:\Users\<user_nam>\AppData\Local\Safe Software\Interoperability\logs
C:\Users\<user_name>\AppData\Roaming\ESRI\Interoperability\logs
The AppData folder noted in the log file is a hidden folder.  It may be necessary to display hidden folders in Windows.
Cause
The cause is due to a change in the way that FME processes workspaces for most string data. This is a known issue, described in a technical article from Safe Software. The article includes a tested, effective workaround.
Solution or Workaround
See the article from Safe Software in the Related Information section.
Article ID: 000032414
Software:
  • ArcGIS Data Interoperability
  • ArcGIS Data Interoperabilityx
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
