PROBLEM
Data added to a group layer adds in reverse order of data added with Add Data button
In ArcMap, when adding several layers to a group layer at once, the order of layers of the same feature class is the opposite of adding the same layers at once as standalone layers in the map.
Cause
Layers are added in reverse order when adding several layers at once to a group layer.
Solution or Workaround
There are two workarounds:
  • Add your layers to the group layer one by one.
  • After adding several layers to a group layer at once, use the Group Layer dialog box to reorder them.
    [O-Image] GroupLayerPropertiesDIgBox
Article ID: 000004409
Software:
  • ArcMap 8 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
