PROBLEM
When edits are made and saved in an IPS-aware web map using the Map Viewer in ArcGIS Enterprise 11.5, the custom IPS Configuration settings are not retained and instead revert to the default values. To find what the default values are, refer to the Configure an IPS-aware map documentation.
The image below displays the IPS Configuration tab of the web map’s Map Properties in ArcGIS Pro, before making and saving any changes in the Map Viewer. The custom Configuration settings are applied.
The following image shows an example of modifying the web map in the Map Viewer by applying different symbology to a layer.
The image below shows the IPS Configuration tab of the web map’s Map Properties in ArcGIS Pro after applying and saving a change in the Map Viewer. Notice that the configuration settings are no longer the same, as they have reverted to the default values.
IPS Configuration settings in Map Properties are available in ArcGIS Pro 3.4 version and later.
There are two workarounds to preserve custom IPS configuration settings when editing a web map in ArcGIS Enterprise 11.5.
As an alternative, use Map Viewer Classic to make edits while retaining custom IPS configuration settings.
Article ID: 000038826
Get help from ArcGIS experts
Start chatting now
