PROBLEM
When a mosaic dataset is created, the attribute table of the mosaic dataset contains several default fields, and custom fields can be added and populated in the attribute table. These fields are used when defining a query on the mosaic dataset or image service that uses the mosaic dataset. In some instances, the custom fields are not carried over when the mosaic dataset is published as an image service.
A possible cause is that the custom fields of the mosaic dataset are disabled in the Allowed Fields parameter within the Mosaic Dataset Properties dialog box before publishing the mosaic dataset as an image service.
Note: All attribute table fields are displayed in the mosaic dataset's attribute table and the Identify window, even if the fields are not allowed for transmission. The Configure Allow List dialog box provides the capability to view which fields are visible to the client when the mosaic dataset is served.
Article ID: 000015997
Get help from ArcGIS experts
Start chatting now
