ERROR
Curves are not supported
Error Message
**This issue has been resolved in ArcGIS Server version 9.3.**
When executing the Identify tool or a task against features that contain curved segments in Web applications built with ArcGIS Server for the Microsoft .Net Framework, the following error message may occur:
"Curves are not supported"
Cause
This is a known limit when using the .NET Web ADF at ArcGIS Server version 9.2.
Solution or Workaround
With ArcGIS Server version 9.2, add a code piece to the application's code as shown in ESRI Knowledge Base article 33331.
ESRI Global Account login is required to view the article within the above link.
    Article ID:000009503
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
