BUG
After using ArcMap to convert coverage annotation to geodatabase annotation, curved leader lines are very thick and arrowheads are not visible.
When converting coverage annotation, ArcMap is not correctly converting the leader line thickness.
After conversion, annotation with leader lines is symbolized with a text symbol that has a Simple Line Callout. This line is always 1.0 points thick at the geodatabase annotation's reference scale. ArcMap is unable to correctly calculate a better thickness depending on the reference scale and $SIZE value for the converted annotation.
The converted leader lines will scale, becoming thicker when zooming in and thinner when zooming out, because all ArcGIS text symbol backgrounds will scale with the reference scale. This is correct behavior.
There are three ways to work around or correct this problem:
/* ======================================================================= /* Name: arrow2lines.aml /* Purpose: creates line coverage from annotation arrows, /* if this coverage already exists, it will be deleted. /* Tis aml assumes: /* - annotation has to have subclass name, /* - only one annotation subclass per coverage, /* Usage: Arc: &r arrow2lines /* Arguments: - name of the coverage with annotation /* - name of the annotation subclass /* Date: Jul 20 2000 /* Author: ESRI /* ======================================================================= &args incover sub &severity &error &routine bailout /*&echo &brief /* ERROR CHECKING AND CLEAN UP... &if [null %incover%] or [null %sub%] &then &return &error Usage: &r arrow2lines &if ^ [exists %incover% -cover] &then &return &error Coverage %incover% doesn't exist &if [exists %incover%line -cover] &then kill %incover%line all &describe %incover% &s numannos = %DSC$ANNOS% &if %numannos% = 0 &then &return &error Annotation not present in the coverage &if [exists lincov.gen -file] &then &s delstat = [delete lincov.gen -file] /* OPEN A GENERATE FILE &s funit = [open lincov.gen openstat -write] /* MAIN PROCESSING - FIND OUT WHICH ANNOTATIONS HAVE ARROWS, /* READ ARROWS COORDINATES AND WRITE THEM TO ASCII, GENERATE FILE. display 0 ae ec %incover% ef anno.%sub% sel all &s j = 0 cursor open &do &while %:edit.AML$NEXT% &s arrowpnts = [show anno.%sub% [show select 1] narrow] &if %arrowpnts% > 0 &then &do &s j = %j% + 1 &s record = %j% &s writestat = [write %funit% %record%] &do i = 1 &to %arrowpnts% &s arrow%j%pnt%i% = [show anno.%sub% [show select 1] arrow %i%] &s record = [value arrow%j%pnt%i%] &s writestat = [write %funit% %record%] &end &s record = END &s writestat = [write %funit% %record%] &end cursor next &end &s record = END &s writestat = [write %funit% %record%] &s closestat = [close %funit%] cursor close quit /* from ARCEDIT n /* GENERATE LINE COVERAGE FROM ASCII FILE generate %incover%line input lincov.gen line quit build %incover%line line /* SHOWING THE RESULTS ae &if [extract 1 [show display]] ne 9999 &then display 9999 ec %incover% de arc anno.%sub% bc %incover%line 2 be arc draw &echo &off &ty NOW ZOOM IN TO THE PLACE WHERE YOU KNOW THERE ARE ANNO ARROWS &ty YOU CAN ZOOM IN COUPLE TIMES, ONCE YOU FIND A GOOD SPOT, &ty PRESS ANY KEY TO CONTINUE AN AML.... &ty &pause de anno.%sub% off draw &ty WHAT YOU SEE IN RED COLOR, ARE LINES SIMULATING ANNOTATION ARROWS &ty &return &routine bailout &severity &error &ignore &if [show program] = ARCEDIT &then cursor close &s closestat = [close -all] &echo &off &return
Article ID:000005675
Get help from ArcGIS experts
Download the Esri Support App
