PROBLEM
Creating parcel remainders returns a Construction method error
First Published: May 5, 2016
When creating a parcel remainder by right-clicking the overlaying parcel feature and selecting Parcel Remainder, a "Construction method error" is returned.
[O-Image]
Cause
There have been 2 identified causes of this error:
  • The underlying parcel feature is composed of line strings instead of two-point line segments.
[O-Image]
  • One or more of the parcels involved are missing join links which would create line points. Without the line points, some of the parcel lines are not completely coincident.
User-added image
Solution or Workaround
If the problem was that the parcel contained line strings, follow these instructions to split the line strings:
  1. Open the Parcel Details window.
  2. Click the Lines tab.
  3. Right-click the Line String, and select Split Line String.
  4. Rejoin the parcel to the fabric.
If the problem was that there were missing join links, follow these instructions for each parcel involved in the remainder to create the join links:
  • Select the parcel using the Parcel Select tool
Article ID: 000012332
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
