BUG
Creating or editing a webhook fails when using Microsoft’s Power Automate as a receiver for ArcGIS Enterprise organization webhooks
First Published: September 25, 2025
Last Published: October 2, 2025
Creating or editing a webhook fails when using Microsoft’s Power Automate as a receiver for ArcGIS Enterprise organization webhooks. ArcGIS Enterprise versions 10.7 through 12.0 are impacted.
An error message similar to the following example may be returned when attempting to create a webhook.
Unable to create webhook for the account '0123456789ABCDEF' due to 'Unable to add webhook registry named ‘new webhook’'
Error: 400
Database error occurred while processing webhook with name or id ‘new webhook’ due to 'Unable to add webhook registry named ‘new webhook'.'
error in Portal Directory when creating a webhook
An example JSON message of the error when making the API call is shown in the following image:
error in JSON API call
Portal administrator debug logs show a database exception from the attempt to insert a row.
error in portal admin debug logs
Cause
In August 2025, Microsoft announced changes to the webhook URL provided through Power Automate. Any new flows created that use the “When an HTTP request is received” trigger provide URLs in a new format.
On November 30, 2025, all 'old-format' URLs cease to function, the new format URL must be obtained from the Power Automate flow, and existing webhooks must be updated.
The new format URL has increased in length by over 80 characters — more when using Shared Access Signature (SAS) authentication. Organization webhooks have a maximum of length of 250 characters for the webhook payload URL. All new URLs from the “When an HTTP request is receiver” trigger will exceed the maximum length, and attempting to create or edit a webhook will result in an error as the URL is too large for the field.
Workaround
Webhook workflows may need to be migrated to another platform. Esri is committed to increasing the maximum URL length in ArcGIS Enterprise 12.1
Article ID: 000038275
Software:
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
