PROBLEM
Creating feature classes with the POSTGIS geometry type reports an incorrect SRID or fails when using PostGIS 3.5.3
First Published: September 4, 2025
Last Published: August 13, 2026
The PostGIS 3.5.3 release introduces modifications that prevent the successful creation of feature classes that use the PostGIS geometry type in enterprise geodatabases and databases on PostgreSQL.
Enterprise geodatabases on PostgreSQL
Using ArcGIS Pro to load or create feature classes in an enterprise geodatabase with the PostGIS geometry type appears to be successful. For example, the following output feature class shown in the next image successfully shows the correct spatial reference: SRID 3857 (WGS 1984 Web Mercator).
output feature class appears successful
However, the PostGIS geometry_columns metadata reports an incorrect SRID of 0, as shown in the following image.
SRID incorrect in metadata reports
Databases on PostgreSQL
Using ArcGIS Pro to load feature classes into a database with the PostGIS geometry type fails with a check constraint violation error. The following error is also encountered when using PostGIS 3.6.0:
Error returned when copying and pasting a feature class into a database:
error returned when copy/pasting
ERROR 000260: A check constraint violation has occurred.[ERROR:  new
row for relation "botswana_tpoint" violates check constraint
"enforce_srid_shape" DETAIL:  Failing row contains (1, Botswana, BWA,
Africa, Primary land, 5, Botswana, 1, 010100000038014D54A338444150840D3F9E6043C1).:SQLSTATE=23514]--A check
ArcGIS Enterprise on Kubernetes deployments using a cloud relational store
ArcGIS Enterprise on Kubernetes allows organizations to configure the relational store using a cloud database service. For organizations who have configured a cloud relational store, it is important to ensure that the PostGIS extension used is not 3.5.3 or 3.6.0.
Solution or Workaround
ArcGIS Pro and ArcGIS Enterprise support PostGIS 3.x, except for versions 3.5.3 and 3.6.0, which are not supported due to PostGIS issue #5978. This issue is resolved in PostGIS versions 3.5.4 and 3.6.1
Article ID: 000037924
Software:
  • ArcGIS Pro
  • ArcGIS Enterprise
  • ArcGIS Enterprise on Kubernetes
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
