PROBLEM
Creating a new SQL Server database connection in ArcGIS Pro causes error "Conflicting partial connection parameters"
Last Published: October 8, 2025
In ArcGIS Pro, when making a new database connection to a SQL Server database for the Database Administorator (sa), the process fails when attempting to activate the drop-down Database list with the error:
Cause
There are multiple potential causes, including:
  • Cached settings in ArcGIS Pro
  • Incorrect parameters for the database connection
  • Unsteady network connectivity
Solution or Workaround
  • Go to the Project tab > Options.  In the Application > Display window, check the box to "clear cache."  ArcGIS Pro must be restarted for this to take effect.
  • Ensure that all required fields in the database connection dialog are correct:
    • Database Platform: Confirm that "SQL Server" is selected.
    • Instance: Ensure the SQL Server instance name or IP address is correct. If a port number is required, include it in the format: server_name,port_number
    • Authentication Type: Ensure "Database Authentication" is selected.
    • Username and Password: Verify the "sa" username and password are correct.
    • Database: Ensure the correct database name is selected or entered.
  • Confirm basic connectivity with the "ping" command or "Test-NetConnection".
  • Attempt to connect to the database as "sa" using SQL Server Management Studio or ODBC Data Source Administrator.
  • Start SQL Server Configuration Manager and ensure that the instance has the TCP/IP network protocol enabled.
Article ID: 000038234
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
