PROBLEM
Creating a new line feature may result in a feature with no shape
Creating a new line feature, whose length is less than the precision of the dataset, results in a feature without a shape to be added.
Cause
When creating new features, the shape is snapped to the precision of the spatial reference of the target layer.
If the distance between vertices in the sketched shape is less than the precision of the target layers' feature class, vertices will collapse and a feature will be created with a null shape.
Solution or Workaround
Contact your database administrator. The precision settings for your data are most likely incorrect.
Please refer to Building a Geodatabase for additional information about precision and setting the spatial reference.
Article ID: 000004266
Software:
  • ArcMap 8 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
