ERROR
Creating a multiversion view returns the following error:
"Error: Table is not multiversion, but must be for this operation (-178).".
Code: C:\>sdetable -o create_mv_view -T parcels_view -t parcels -i 5151 -u sde -p sde ArcSDE 9.2 for Oracle10g Build 449 Wed Jan 16 12:20:02 2008 Attribute Administration Utility ----------------------------------------------------- Error: Table is not multiversion, but must be for this operation (-178). Error: Unable to create MV view parcels_view for table parcels.
Multiversion views require the underlying table or layer to first be registered as versioned. If the table or layer is not registered as versioned, the above error is returned.
Register a table or layer as versioned in ArcGIS by using ArcCatalog:
Article ID:000009834
Get help from ArcGIS experts
Download the Esri Support App
