HOW TO
Create labels on contour lines using Mask and Halo
Summary
This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Follow these steps to place a contour label in ArcMap.
Procedure
  1. Right-click the layer name in the ArcMap table of contents and select Properties.
  2. Click the Labels tab to set the contour line properties.
    1. Verify the Label features box is checked.
    2. In the Method drop-down box choose Label all the features the same way.
    3. In the Label drop-down box choose the field that contains contour values.
    4. Click Placement Properties.
    5. Set the constraint placement to On the Line. Make sure to uncheck the Above line option on the left. Click OK.
  3. Click the Symbol button to view the Symbol Selector window and adjust the labels.
    1. Select the desired label font, color, and size.
    2. Click the Properties button.
    3. Click the Mask tab.
    4. Click the Halo button and adjust the halo to the desired size.
  4. Click OK to close the Editor window, and OK again to close the Symbol Selector window.
  5. Click Apply > OK, and Zoom to view contour labeling.
[O-Image] Contour Line label example
Article ID:000002288
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
