HOW TO
When using MapObjects-Java Standard Edition (MOJ), a developer may choose to dynamically create and display graphical features, including text, with data layers in a Map component. The geometry of the graphic components in a dynamic layer is created at runtime, either in the application code or using a data file, such as a text file with x and y coordinates. Different methods can be used to generate a dynamic layer, depending on the extent to which the developer needs to interact with the data in the layer. Three primary techniques are available:
public class MyAcetateLayer extends com.esri.mo.ui.bean.AcetateLayer{ com.esri.mo.ui.bean.Map m_map; com.esri.mo.map.draw.SimpleFillSymbol sps; com.esri.mo.map.draw.SimpleLineSymbol sls; public MyAcetateLayer(com.esri.mo.ui.bean.Map map){ m_map = map; sps = new com.esri.mo.map.draw.SimpleFillSymbol(); sps.setType(sps.FILLTYPE_CROSS); sps.setSymbolColor(java.awt.Color.green); java.awt.BasicStroke bs = new java.awt.BasicStroke(3.0f); sls = new com.esri.mo.map.draw.SimpleLineSymbol(); sls.setStroke(bs); sls.setLineColor(java.awt.Color.yellow); } public void paintComponent(java.awt.Graphics g){ // Call the superclass paint component to clear the off-screen buffer super.paintComponent(g); // Retrieve the current graphics component java.awt.Graphics2D g2d = (java.awt.Graphics2D) g; /* Use the Map component to create a Transform - used to convert world coordinates to pixel cooridinates in the Map display */ com.esri.mo.cs.geom.Transform t = m_map.getWorldToPixelTransform(); // Create the features to be displayed in the AcetateLayer double[] xx = {-90.0, -110.0, -100.0, -90}; double[] yy = {30.0, 40.0, 50.0, 30.0}; com.esri.mo.cs.geom.BasePointsArray bpa = new com.esri.mo.cs.geom.BasePointsArray(xx,yy); com.esri.mo.cs.geom.BasePolyline bpl = new com.esri.mo.cs.geom.BasePolyline(new com.esri.mo.cs.geom.BasePath(bpa)); com.esri.mo.cs.geom.BasePolygon bp = new com.esri.mo.cs.geom.BasePolygon(new com.esri.mo.cs.geom.BaseRing(bpa)); g2d.transform(t.toAffine()); sps.draw(bp,g2d,"test"); sls.draw(bpl,g2d,"test"); } }
MyAcetateLayer alayer = new MyAcetateLayer(aMap); aMap.add(alayer);
import com.esri.mo.cs.geom.*; import com.esri.mo.map.draw.*; import com.esri.mo.data.feat.*; import com.esri.mo.map.dpy.*; import java.awt.*; public class MyGraphicsLayer extends BaseGraphicsLayer { public MyGraphicsLayer(){ // Create fields to hold the feature geometry and attributes BaseField fld1 = new BaseField("shape", Field.ESRI_SHAPE, 0,0); BaseField fld2 = new BaseField("string", java.sql.Types.VARCHAR, 10,0); BaseFields bfs = new BaseFields(); bfs.addField(fld1); bfs.addField(fld2); // Create the feature geometry double[] xx = {-90.0, -110.0, -100.0}; double[] yy = {30.0, 40.0, 50.0}; BasePointsArray bpa = new BasePointsArray(xx,yy ); com.esri.mo.cs.geom.BasePolygon bp = new com.esri.mo.cs.geom.BasePolygon(new BaseRing(bpa)); // Create a and add the geomtery and attributes BaseFeature bf = new BaseFeature(); bf.setFields(bfs); bf.setValue(0, bp); bf.setValue(1, "Area 1"); // Create an Element to add to the GraphicsLayer BaseFeatureElement bfe1 = new BaseFeatureElement((BaseFeature) bf.clone()); // Set the renderer for the Element BaseSimpleRenderer rd = new BaseSimpleRenderer(); SimplePolygonSymbol symbol = new SimplePolygonSymbol(); symbol.setPaint(new Color(0,20,250)); rd.setSymbol(symbol); bfe1.setRenderer(rd); // Add Element to the GraphicsLayer this.addElement(bfe1); } }
MyGraphicsLayer glayer = new MyGraphicsLayer(); AcetateLayer aglayer = new AcetateLayer(glayer); aMap.add(aglayer);
public class MyFeatureLayer extends BaseFeatureLayer { BaseFields fields; private Vector featureStorage; public MyFeatureLayer() { createFeaturesAndFields(); /* Retrieve and set the feature class for this FeatureLayer * "MyData" can be replaced with any String value, it will be used * as the layer name in the legend entry */ BaseFeatureClass bfc = getFeatureClass("MyData"); setFeatureClass(bfc); // Construct and set the renderer for this FeatureLayer BaseSimpleRenderer rd = new BaseSimpleRenderer(); SimplePolygonSymbol symbol = new SimplePolygonSymbol(); symbol.setPaint(new Color(250,0,20)); rd.setSymbol(symbol); setRenderer(rd); /* Call local method to set layer capabilities. Since the capabilities of a * FeatureLayer must be set before it will display, and the setCapabilities() * method has protected access, a dynamic FeatureLayer must subclass BaseFeatureLayer */ MyLayerCapabilities lc = new MyLayerCapabilities(); setCapabilities(lc); } private void createFeaturesAndFields(){ featureStorage = new Vector(); fields = new BaseFields(); createDbfFields(); /* Create a new BaseFeature and set the fields template. Assign a unique DataID for * each feature. */ BaseFeature feature = new BaseFeature(); feature.setFields(fields); feature.setDataID(new BaseDataID("myData",0)); double[] xx = {-90.0, -110.0, -100.0}; double[] yy = {30.0, 40.0, 50.0}; BasePointsArray bpa = new BasePointsArray(xx,yy ); com.esri.mo.cs.geom.BasePolygon bp = new com.esri.mo.cs.geom.BasePolygon(new BaseRing(bpa)); feature.setValue(0, bp); feature.setValue(1, new Integer(2)); featureStorage.addElement(feature); } private void createDbfFields() { fields.addField(new BaseField("#SHAPE#", Field.ESRI_SHAPE, 0, 0)); fields.addField(new BaseField("ID", java.sql.Types.INTEGER, 9, 0)); } public BaseFeatureClass getFeatureClass(String Name) { com.esri.mo.map.mem.MemoryFeatureClass featClass = null; try{ // Set the feature type to the appropriate value (POLYGON, LINE, POINT) featClass = new com.esri.mo.map.mem.MemoryFeatureClass(MapDataset.POLYGON, fields); } catch (IllegalArgumentException ie) { System.err.println("error creating the base class ="+ie.toString()); } featClass.setName(Name); featClass.addFeature((Feature) featureStorage.elementAt(0)); return featClass; } private final class MyLayerCapabilities extends com.esri.mo.map.dpy.LayerCapabilities { MyLayerCapabilities() { for (int i = 0; i < this.size(); i++) { setAvailable(this.getCapabilityName(i),true); setEnablingAllowed(this.getCapabilityName(i),true); getCapability(i).setEnabled(true); } } } }
MyFeatureLayer flayer = new MyFeatureLayer(); flayer.setVisible(true); aMap.getLayerset().addLayer(flayer);
Get help from ArcGIS experts
Download the Esri Support App
