HOW TO
Create a raster catalog table in a geodatabase in 8.x
Summary
Instructions provided describe how to create a raster catalog in a geodatabase. Raster catalogs are supported in the file system and in geodatabases.
Procedure
Select a procedure below.
ArcGIS 8.x
Create a table for the raster catalog in the geodatabase where all the rasters are stored. The table must have at least the following five fields: IMAGE, XMIN, YMIN, XMAX, and YMAX. The format for the IMAGE field is:
Code:
[<database>].<owner>.<raster_name>
Where:
[<database>] - name of the database in the ArcSDE/RDBMS. This is not
required for certain RDBMS (ie. Oracle).
<owner> - name of owner of the files.
<raster_name> - name of the individual raster.
The IMAGE name field should be a string type, and the extent fields can be any integer or float numeric type.
You are able also able to create a raster catalog (.dbf file) by using the 'Create Raster Catalog From a Directory' sample script on the Raster section of the ArcObjectsOnline webpage (https://arcobjectsonline.esri.com/).
ArcGIS 9.0
For details on creating the table in a geodatabase (ArcGIS 9.0 and above), see the online help under:
Working with geodatabases > Creating new items in geodatabases > Creating tables > How to create tables > Creating a table to store simple objects.
All the rasters in a raster catalog must be in the same geodatabase connection.
Article ID: 000003184
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
