HOW TO
Create a dynamic point feature class from an SQL database table using a query
First Published: September 28, 2026
Last Published: September 28, 2026
Summary
In ArcGIS Pro we can create a dynamic feature class from an SQL database table using the New Query Layer dialog box. Any data updates in the SQL table are automatically reflected on the feature class.
Procedure
Prerequisites:
Latitude and Longitude columns should be present in the SQL table.
Workflow:
  1. In ArcGIS Pro, create a database connection with the SQL database.
  2. In the Catalog pane right-click Databases > New Database Connection > Add the Connection properties, select the database and click Validate.
  3. Navigate to the Map tab. Under Add Data select Query Layer.
    The New Query Layer dialog box opens:
  4. In Datasource select the SQL database connection.
  5. For Name, provide a name for the query.
  6. Under Query add the following query:
SELECT *,geometry::Point(Latitude, Longitude, 4326) AS SHAPE From sde.table_name
Example:
SELECT *,geometry::Point(Latitude, Longitude, 4326) AS SHAPE FROM sde. TEST_1
  1. Validate the query and click Next.
  2. Select a Unique Identifier Field such as the OBJECTID.
creating the query
  1. Add the Spatial Properties and the SRID.
  2. Click Finish.
After following these steps, we can create a dynamic feature class in ArcGIS Pro. We can publish this feature class to ArcGIS Enterprise as a referenced feature service.
Article ID: 000042724
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
