HOW TO
You can use Avenue to create a Database Theme with the fields defined by a SQL statement. The sample script below demonstrates how to create a DBtheme with all columns, for example: Select * From table.
Code:
'-- Get view
aView = av.GetProject.FindDoc("View1")
'-- Establish connection parameters
serv = "SERVERNAME"
inst = "INSTANCE"
datab = ""
user = "USERNAME"
pass = "PASSWORD"
'-- Make sde connection with above parameters
anSDECon = SDEConnection.Make(serv+":"+inst, datab, user,pass)
'-- Make a querydef object of the connection
aQDef = SDEQueryDef.Make(anSDECon)
'-- Use sql select statement "select *" to get all fields
aQDef.SetSQL("Select * from TABLE.NAME")
'-- Make a dbtable from this querydef object
aDBtable = DBtable.Make(aQdef)
'-- Get all fieldnames for use in the dbtheme
theFields = aDBtable.GetFields
'-- Make another querydef object for dbtheme
aQdef2 = SDEQueryDef.Make(anSDECon)
'-- Pass fieldnames list to the SetSelectColumns
aQDef2.SetSelectColumns(theFields)
'-- From statement
aQDef2.SetFromTables({"TABLE.NAME"})
'-- Make scolumn and dbtheme
theSCol = SDESColumn.Make(anSDECon, "TABLE.NAME", "Shape")
theDBTheme = DBTheme.Make(aQDef2, theSCol, Polygon)
aView.AddTheme(theDbtheme)
SERVERNAME - Name of the SDE server
INSTANCE - Instance found in the Services File
USERNAME - SDE login name
PASSWORD - SDE password
TABLE.NAME - Name of table to query
Article ID:000002697
Get help from ArcGIS experts
Download the Esri Support App
