ERROR
Coverage is not a valid Cover, Grid, Tin or Stack
Error Message
Selecting the input coverage when running the Define Projection Wizard(coverages, grids, TINs) in ArcToolbox returns the error:
"<In_Coverage> is not a valid Cover, Grid, Tin, or Stack"
Cause
The coverage is missing the TIC and BND files.
Solution or Workaround
Create TIC and BND files for a coverage called PNTCOV.
  1. Use the DESCRIBE command in ArcInfo Workstation to determine if the input coverage is single or double precision. The first line of the information returned by DESCRIBE will show the keyword SINGLE or DOUBLE.
    Code:
    Arc: describe pntcov
    Description of SINGLE precision coverage pntcov
  2. Define new TIC and BND files for the coverage based on the precision of the coverage.
    Single precision:
    Arc: INFO
    ENTER USER NAME>ARC
    ENTER COMMAND >DEFINE PNTCOV.TIC
    ITEM NAME>IDTIC,4,5,B
    ITEM NAME>XTIC,4,12,F,3
    ITEM NAME>YTIC,4,12,F,3
    ITEM NAME>
    ENTER COMMAND >ITEMS
    1 IDTIC 4 5 B -
    5 XTIC 4 12 F 3
    9 YTIC 4 12 F 3
    ENTER COMMAND >DEFINE PNTCOV.BND
    ITEM NAME>XMIN,4,12,F,3
    ITEM NAME>YMIN,4,12,F,3
    ITEM NAME>XMAX,4,12,F,3
    ITEM NAME>YMAX,4,12,F,3
    ITEM NAME>
    1 XMIN 4 12 F 3
    5 YMIN 4 12 F 3
    9 XMAX 4 12 F 3
    13 YMAX 4 12 F 3
    ENTER COMMAND >Q STOP
    OR
    Double precision:
    Arc: INFO
    ENTER USER NAME>ARC
    ITEM NAME>XTIC,8,18,F,5
    ITEM NAME>YTIC,8,18,F,5
    ITEM NAME>
    1 IDTIC 4 5 B -
    5 XTIC 8 18 F 5
    13 YTIC 8 18 F 5
    ITEM NAME>XMIN,8,18,F,5
    ITEM NAME>YMIN,8,18,F,5
    ITEM NAME>XMAX,8,18,F,5
    ITEM NAME>YMAX,8,18,F,5
    ITEM NAME>
    1 XMIN 8 18 F 5
    9 YMIN 8 18 F 5
    17 XMAX 8 18 F 5
    25 YMAX 8 18 F 5
  3. Use the EXTERNAL command to external the PNTCOV.TIC and PNTCOV.BND files to the appropriate files in the PNTCOV folder.
    Code:
    Usage: EXTERNAL <geo_dataset>
    Arc: external pntcov
  4. Use the Define Projection Wizard(coverages, grids, TINs) to define a projection for the coverage.
Article ID:000005657
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
