ERROR
Could not start the Server Manager Service on the Local Computer. Error: Access is Denied
Error Message
When opening the ArcGIS Server Manager, the Manager page does not open. The ArcGIS Server Manager service also fails to start with the following error:
"Could not start the Server Manager Service on the Local Computer. Error: Access is Denied"
Cause
The ArcGIS Server Object Manager account (ArcGISSOM) does not have at least read access to the directory %ArcGISHome%\Java\Manager.
Solution or Workaround
The directory, ArcGISHome%\Java\Manager, contains the files and folders necessary to run the internal Web server that is installed by default with ArcGIS Server for Java. If the ArcGISSOM account is unable to read the files and folders in this directory, the Web server cannot start, and ArcGIS Server Manager will be inaccessible.
  1. Open Windows Explorer and navigate to the %ArcGISHome%\Java\Manager directory (folder).
  2. Right-click this folder and select 'Properties'.
  3. Select the 'Security' tab.
  4. Ensure that the ArcGISSOM account has at least read access to the %ArcGISHome%\Java\Manager directory.
Article ID: 000010581
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
