HOW TO
Instructions provided describe how to copy or load data and preserve GlobalID values with VBA. There are two approaches that can be used to do this using ArcObjects. The SDK article, How to copy or load data and preserve GlobalID values, has a more detailed discussion on this and includes .NET code. This article includes VBA versions of the code in that article.
Code:
' Code for Approach 1
' converts a Globalid to a GUID
Sub GlobalID_to_GUID()
' Get the table
Dim pGxApp As IGxApplication
Set pGxApp = Application
Dim pGxObj As IGxObject
Set pGxObj = pGxApp.SelectedObject
Dim pName As IName
Set pName = pGxObj.InternalObjectName
Dim pTable As ITable
Set pTable = pName.Open
' Get the globalid field
Dim classEX As IClassEx
Dim pDSet As IDataset
Set classEX = pTable
If (Not classEX.HasGlobalID) Then
Set pDSet = pTable
MsgBox "No globalid field exists for table: " & pDSet.Name
Exit Sub
End If
' Convert the GlobalID column to a GUID column
Dim schemaEdit As IClassSchemaEditEx
Set schemaEdit = pTable
schemaEdit.UnregisterGlobalIDColumn classEX.GlobalIDFieldName
End Sub
' converts a GUID to a GlobalID
Sub GUID_to_GlobalID()
' Get the table
Dim pName As IName
' Get the GUID field to convert
Dim fields As IFields
Dim i As Integer
Set fields = pTable.fields
i = fields.FindField("globalid")
If (i = -1) Then
Set pDSet = pTable
MsgBox "A field named globalid does not exist in table: " & pDSet.Name & _
". If the field that you want to convert has another name, adjust the code and re-run it."
Exit Sub
End If
' make sure it is of type GUID
Dim GUIDField As IField
Set GUIDField = fields.Field(i)
If (GUIDField.Type <> esriFieldTypeGUID) Then
MsgBox "Field " & GUIDField.Name & " is not of type GUID"
Exit Sub
End If
' Convert the GUID column to a GlobalID column
schemaEdit.RegisterGlobalIDColumn GUIDField.Name
End Sub
Code:
' Code for Approach 2
' Export the table to updategram
Sub Export_table_to_updategram()
' Get the table
Dim pName As IName
' unqualify the table name
Dim unqualTableName As String
Set pDSet = pTable
unqualTableName = pDSet.Name
unqualTableName = Right(unqualTableName, Len(unqualTableName) - InStr(unqualTableName, "."))
' initialize the TablesDataChanges with inserts only
Set pDSet = pTable
Dim tableDataChangesInfo As ITableDataChangesInfo
Set tableDataChangesInfo = New tableDataChangesInfo
tableDataChangesInfo.Init unqualTableName, pTable, Nothing, Nothing
Dim tablesDataChanges As ITablesDataChanges
Set tablesDataChanges = New tablesDataChanges
tablesDataChanges.Init esriReplicaModelType.esriModelTypeFullGeodatabase
tablesDataChanges.Add tableDataChangesInfo
Dim dataChanges As IDataChanges
Set dataChanges = tablesDataChanges
' Use the TablesDataChanges to generate an updategram
Dim path As String
path = Environ("temp")
Dim detlaFile As String
detlaFile = path & "\updategram_of_table_" & unqualTableName & ".xml"
Dim DataChangesExporter As IExportDataChanges
Set DataChangesExporter = New DataChangesExporter
DataChangesExporter.ExportDataChanges detlaFile, esriExportDataChangesOption.esriExportToXML, dataChanges, True
InputBox "Table or feature class " & pDSet.Name & " has been export to the following updategram:", "Export to delta file", detlaFile
End Sub
' Imports from a delta file
' NOTE: you will need to change the following path in the code "d:\temp\expver.xml"
Sub impDataChanges()
' Get the ArcSDE workspace
Dim pName As IName
Dim pWkSpname As IWorkspaceName
Set pWkSpname = pName
Dim pDelChgs As IDeltaDataChangesInit
Set pDelChgs = New DeltaDataChanges
pDelChgs.Init "d:\temp\expver.xml", esriExportToXML
Dim pImpDC As IImportDataChanges
Set pImpDC = New DataChangesImporter
pImpDC.ImportDataChanges pWkSpname, pDelChgs, False, False
End Sub
Article ID:000010306
Get help from ArcGIS experts
Download the Esri Support App
