HOW TO
Convert GTOPO30 DEM data into a grid using ArcINFO GRID
Summary
Instructions provided describe how to convert GTOPO30 DEM data into a grid. Use ArcInfo GRID to convert a USGS GTOPO30 DEM to grid format while retaining the digital elevation data values.
Click the link in the Related Information section to download a GTOPO30 DEM. This file comes as a .TAR file, which contains the *.dem and *.hdr files. Both files are required for this operation.
Procedure
Follow the steps below.
  1. Uncompress the .TAR file using WinZip 6.2 or higher.
  2. Change the *.dem extension to *.bil.
  3. Use IMAGEGRID at the Arc prompt to convert the *.bil to a grid.
  4. Use the CON statement in GRID:
    Code:
    out_grid = CON(in_grid >= 32768,in_grid - 65536,in_grid)
  5. Convert the ocean areas (-9999), if desired, to NODATA using SETNULL:
    Code:
    out_grid2 = SETNULL(out_grid == -9999,out_grid)
Article ID: 000001968
Software:
  • Legacy Products
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
