HOW TO
Convert Global Positioning System (GPS) points to a State Plane coordinate system
Summary
Instructions provided describe how to convert Global Positioning System (GPS) coordinates to a State Plane coordinate system.
Procedure
  1. Create a table in a file geodatabase with the field names Latitude and Longitude, with Long Integer as the data type.
  2. Edit the table and enter in the points in decimal degrees.
    Manually convert the degrees-minutes-seconds to decimal degree values using the Field Calculator in ArcMap. Follow the instructions in the following ArcGIS Help document: Converting degrees-minutes-seconds values to decimal degree values
  3. Once the coordinates are entered, navigate to the Table of Contents and right-click the table > Display XY Data.
  4. Select the X Field as Longitude and the Y Field as Latitude from the dropdown menu.
    [O-Image]
  5. Click the Edit button to select the appropriate geographic coordinate system (WGS 1984 is used for most GPS points), and click OK. This adds a layer to the map named '<geodatabase filename> Events'.
  6. Change the coordinate system of the data frame to the desired State Plane system.
  7. Right-click the added layer and navigate to Data > Export Data.
  8. Select the 'Use the same coordinate system as: the data frame' option, and select the output location. Click OK. The new feature class is added to the map.
  9. Open the attribute table of this new feature class and add a new text field.
  10. Right-click the new field and navigate to Calculate Geometry. If prompted about being outside of an edit session, feel free to proceed or begin an edit session. In the Calculate Geometry window, select the 'X Coordinate of Point' property, and 'Use the coordinate system of the data source' option. Click OK.
    The State Plane X-coordinates are now in that field.
  11. Repeat Steps 9 and 10 for the Y coordinates.
Article ID: 000012108
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
