HOW TO
This Avenue script shows how to convert a set of user-supplied coordinates in Decimal Degrees to State Plane coordinates or viceversa.
Code:
'--- Script DD-SPF.AVE
'-- This script addresses the need to project TO and FROM Texas
'-- North-Central State Plane, NAD27, map units FEET.
'-- It prompts you for the coordinate input.
'-- If the input coordinates are in State Plane, the script converts
'-- them to DD and displays them.
'-- If the input coordinates are in DD, the script converts them
'-- to State Plane and displays them.
'-- If the DD X/Longitude coordinate is a positive number, the script
'-- converts it to a negative number before unprojecting it,
'-- assuming the data is located in the Western Hemisphere.
'-- Since ArcView calculates projections using meters, it is
'-- necessary to multiply State Plane coordinates by 3.2808
'-- after projecting them. It is also necessary to divide
'-- State Plane coordinates by 3.2808 before unprojecting them.
'-- If your State Plane map units are in meters, this extra
'-- processing is not needed.
theView = av.getactivedoc
r = Rect.MakeXY(-180,-90,180,90)
mySP = Lambert.Make(r)
mySP.SetCentralMeridian(-97.5)
mySP.SetReferenceLatitude(31.6667)
mySP.SetLowerStandardParallel(32.1333)
mySP.SetUpperStandardParallel(33.9667)
mySP.SetFalseEasting(609601)
mySP.SetFalseNorthing(0)
theLabels = {"Long-X","Lat-Y"}
theDefs = {"",""}
theInCoords = MsgBox.MultiInput
("Enter Coords either DD or Stateplane",
"",theLabels,theDefs)
theXval = theInCoords.Get(0).AsNumber
theYval = theInCoords.Get(1).AsNumber
thePoint = Point.Make(theXval,theYval)
if (theXval < 180)
then
if (theXval > 0)
then 'just in case the input DD longitude is positive.
thePoint.SetX(theXval * -1)
end
mySP.ProjectPt(thePoint)
theX = ((thePoint.GetX) * 3.2808).SetFormat("d.d").AsString
theY = ((thePoint.GetY) * 3.2808).SetFormat("d.d").AsString
theFinalLabel = "DD converted into Stateplane"
else
thePoint.SetX(theXval / 3.2808)
thePoint.SetY(theYval / 3.2808)
mySP.UnprojectPt(thePoint)
theX = thePoint.GetX.SetFormat("d.dddd").AsString
theY = thePoint.GetY.SetFormat("d.dddd").AsString
theFinalLabel = "Stateplane converted into DD"
end
MsgBox.Info("Longitude/X-coord"++theX+NL+"Latitude/Y-coord"++theY,
theFinalLabel)
'--- End of Script
Article ID:000002507
Get help from ArcGIS experts
Download the Esri Support App
