HOW TO
Convert a number field to a string field with commas using Avenue
Summary
Use the script below to create a string field based on a number field so commas can be displayed.
Procedure
  1. Open a new script window.
    A. Activate the Project window.
    B. Click the Scripts icon.
    C. Click New.
  2. Copy the code into the new script window.
    Code:
    'This script assumes that a table is the active document
    'It will prompt you for the numeric field that you want to
    'convert to a string field with commas.
    'It will also ask you for a name for the new string field
    'The script will put your table in edit mode, add the new field,
    'populate the field and then save the changes and stop editing.
    aTable = av.GetActiveDoc 'Gets active table
    aVtab = aTable.GetVtab
    flds = aVtab.GetFields
    f_List = List.Make
    for each f in flds
    if (f.IsTypeNumber) Then
    nf = f_List.Add(f)
    end
    end
    select = MsgBox.ListAsString(f_List,"Select a Number Field","Selection")
    newFieldName = MsgBox.Input("Please input a name for the new string field:", "New Field","Comma")
    newfld = Field.Make(newFieldName,#FIELD_CHAR,20,0)
    aVtab.SetEditable(true)
    aVtab.AddFields({newfld})
    For each rec in aVtab
    aVal = aVtab.ReturnValueNumber(select,rec)
    'MsgBox.Info(aVal.AsString,"aVal")
    com = ","
    c = aVal.AsString.Count
    If (c = 4) Then
    num = (aVal.AsString.Left(1))+(com+aVal.AsString.Right(3))
    ElseIf (c = 5) Then
    num = (aVal.AsString.Left(2))+(com+aVal.AsString.Right(3))
    ElseIf (c = 6) Then
    num = (aVal.AsString.Left(3))+(com+aVal.AsString.Right(3))
    ElseIf (c = 7) Then
    num =
    (aVal.AsString.Left(1))+(com+aVal.AsString.Middle(1,3))+(com+aVal.AsString.Right(3))
    ElseIf (c = 8) Then
    num =
    (aVal.AsString.Left(2))+(com+aVal.AsString.Middle(2,3))+(com+aVal.AsString.Right(3))
    ElseIf (c = 9) Then
    num =
    (aVal.AsString.Left(3))+(com+aVal.AsString.Middle(3,3))+(com+aVal.AsString.Right(3))
    else
    num = aVal.AsString
    end 'end If Then
    aVtab.SetValue(newfld,rec,num)
    end 'For
    aVtab.SetEditable(false)
  3. Compile the script by clicking the compile button.
    [O-Image] Script compile button
  4. Run the script by clicking the run button.
    [O-Image] Run compiled script button
Article ID:000005042
Software:
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
