HOW TO
Controlling fonts and colors in AML menus (Motif only)
Procedure
Question:
How can the font in an AML menu be changed or set?
Cause:
Not applicable
Answer:
Fonts and colors in AML menus on platforms using MOTIF are controlled using a
file called "Arcinfo". There is a sample Arcinfo file under $ARCHOME/Xenv. To
see how the Arcinfo file works, copy the sample to your home directory. When
you start ARC/INFO and call up a menu, you will see different colors and
perhaps a different font.
More samples are at $ARCHOME/arctools/sysfiles:
Arcinfo_blue_and_green
Arcinfo_gray
Arcinfo_wheat
If you want to use one of these, copy the file to your home directory and
rename the file as Arcinfo.
You can specify different colors and fonts in the Arcinfo file, provided they
are recognized by your system.
FONTS:
The font is specified like this:
Arcinfo*FontList: rock18
Article ID:000001358
Software:
  • ArcMap 8 x
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
