HOW TO
Connect the Freefly Astro Pilot Pro controller to the ArcGIS Flight app
Last Published: April 15, 2025
Summary
This article describes how to use the ArcGIS Flight app in conjunction with a Freefly Pilot Pro controller and Astro drone.
Procedure
The RJ45 port (Ethernet) on the Pilot Pro radio module is a gateway for the iPad to tap into the drone's internal radio network.
Prerequisites
  • RJ45 Ethernet cable
  • USB-C to Ethernet adapter
  • iPad
For the iPad to work with the Pilot Pro controller, it is necessary to use an iPad with a USB-C port and at least iPadOS 16.0 or later.
Steps to connect the Pilot Pro controller to the iPad
  1. For Blue UAS aircraft, use the Pilot Pro app to enable the ethernet port (Off by default).
  2. Ensure the drone is on the ground and disarmed.
  3. Connect the iPad to the controller via Ethernet cable.
  4. Change the iPad's IP address for the Ethernet connection to:
    • IP address: any value in the following range 192.168.144.100-150
    • Netmask 255.255.255.0
    • Gateway - do not populate, you can use 192.168.144.12 if required
    • DNS - do not populate
  5. To make a connection to the drone, open ArcGIS Flight.
  6. Once you access your project, select Astro Wired as your drone.
If your drone connection has been established correctly, you should see the connection status as a green dot next to the drone model, and telemetry information should appear.
This setup is only needed once per initial connection between ArcGIS Flight and the Pilot Pro controller. If you experience any connectivity issues, please contact Esri Technical Support.
Article ID: 000035089
Software:
  • ArcGIS Flight
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
