HOW TO
One of the output options for GeoEvent services on a GeoEvent Server is "Send Features to a Stream Service". If a stream service is published, it can be added as a stream layer to a web map in ArcGIS Online or Portal for ArcGIS, where the style of the layer can be changed, similar to how a feature layer's style is changed. Unique, however, to the style settings of a stream layer is a check box for "Connect Observations".
The Connection Observations check box enables a line on the layer which connects events in the order in which they appear in the data.
The instructions provided describe how to create a connecting line between observations in a stream layer.
Note: Tags must not be added to fields listed under a grouped field in a hierarchical definition, as seen below. These tags are not recognized if publishing a Stream Service based on hierarchical definitions.
Note: Without the TIME_START or TIME-END tag, the Connect Observations setting is visible but does not allow the lines to be drawn.
Article ID: 000016966
Get help from ArcGIS experts
Start chatting now
