HOW TO
Business Analyst Target Marketing infographic templates for the United States have been redesigned and modernized as part of the ArcGIS Pro 3.2 development cycle. These updates improve accessibility, legibility, and overall presentation of the contained data.
These updated templates will be delivered with the local U.S. 2023 Release 2 Business Analyst dataset, available for download on November 9, 2023. Once the Release 2 dataset is set up on your machine, you will be able to use these templates in ArcGIS Pro.
To use the updated templates now, you can follow these steps to manually install them into your existing local U.S. 2023 Business Analyst dataset, known as June 2023, release 1.
Manually updating your U.S. Target Marketing infographic templates requires downloading and unzipping the necessary files, and then copying them into the designated folders.
The location where you will copy these files depends on whether you connected to or installed your existing local U.S. 2023 Business Analyst dataset. Proceed with the appropriate steps below, based on your setup.
You can identify the full path to the dataset by opening ArcGIS Pro, opening Options, and selecting Business Analyst. The path is displayed in this window.
With these steps complete, you are ready to run these updated U.S. Target Marketing infographic templates with the local U.S. 2023 Business Analyst dataset active.
Article ID: 000031495
Get help from ArcGIS experts
Download the Esri Support App
