Summary
Newly created enterprise geodatabases, or geodatabases upgraded using ArcGIS Pro 3.7 and ArcGIS Enterprise 12.1, require an additional library file (libstdc++.so.6) to configure the extproc on systems running Red Hat Enterprise Linux (RHEL) 8 or Oracle Linux 8, including Oracle Exadata systems running Oracle Linux 8.
Procedure
Use the following steps to configure the extproc:
- Review the Configure extproc to access ST_Geometry in Oracle documentation.
- As part of the preparatory steps, download the “ArcGIS Enterprise ST_Geometry Libraries (Oracle)” from My Esri.
- Extract and copy the following required files to the same directory (either $ORACLE_HOME/lib or a separate folder) on the Oracle machine:
- libst_shapelib.so library from the “Linux64” directory
- libstdc++.so.6 library from the “Additional_File_For_RHEL_8” directory
- Update your shell configuration file for the Oracle installation owner by adding the following line:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$ORACLE_HOME/lib
- include the path to the directory containing the libstdc++.so.6 file if it’s not in the $ORACLE_HOME/lib
For example:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$ORACLE_HOME/lib:/usr/arcgislibs
- Continue with the steps under the Configure extproc section of the documentation to complete the external procedure setup in Oracle.
