HOW TO
Configure ArcGIS Server Manager for Java to function after the Server Machine Hostname has changed
First Published: May 5, 2016
Last Published: January 24, 2023
Summary
This article applies to retired ArcGIS versions 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Instructions provided describe how to configure ArcGIS Server Manager for Java to function after the GIS Server machine's hostname has changed.
Procedure
  1. Change the host machine's hostname.
  2. Modify the server name in the file ArcGIS\java\manager\config\applications\defaultservers.xml.
  3. Modify the server name in the file ArcGIS\server\system\server.dat.
  4. Run the application ArcGIS\java\support\serverjavamanager.exe.
  5. Delete all the existing files from the two directories below:
ArcGIS\java\manager\service\tomcat\managerserver\work\Catalina\localhost
ArcGIS\java\manager\service\tomcat\managerappserver\work\Catalina\localhost
New files will be re-created automatically.
  1. Restart the ArcGIS Server Object Manager and Server Manager Services.
  2. Run ArcGIS Server Post Install process.
Article ID: 000010705
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
