HOW TO
​Configure an ArcGIS Pro machine to allow portal connections to ArcGIS Enterprise deployments that use TLS 1.3
Last Published: May 13, 2025
Summary
In ArcGIS Pro, you can add connections to ArcGIS Online and ArcGIS Enterprise to share and access portal content. ArcGIS Enterprise portals can be configured with specific Transport Layer Security (TLS) protocols to secure communication. To add a connection to an ArcGIS Enterprise portal that uses the TLS 1.3 protocol, ensure your ArcGIS Pro machine is configured to support this protocol. Otherwise, you may encounter the following error when adding the portal connection:
Connection Error
Unable to add portal. Please make sure that the specified portal is up, running and the URL is correct.
portal connection error message
This article provides steps for enabling TLS 1.3, which is supported beginning in Windows 11 and Windows Server 2022. Additionally, it’s recommended that you use ArcGIS Pro 3.5 or later to connect to ArcGIS Enterprise portals using TLS 1.3. For a table of supported TLS protocol versions and OS versions, see: Protocols in TLS/SSL (Schannel SSP)
Procedure
To enable TLS 1.3, complete the following steps:
  1. Press the Windows key + R to open the Run dialog box.
  2. Type inetcpl.cpl and press the Enter key, or click OK.
using the Run dialog to access internet properties
  1. In the Internet Properties dialog box, click the Advanced tab.
Accessing the Advanced properties
  1. Under the Security section, check the Use TLS 1.3 check box and click OK.
enabling TLS 1.3
  1. In ArcGIS Pro, add a connection to the ArcGIS Enterprise portal that uses the TLS 1.3 protocol. For more information, see Manage portal connections from ArcGIS Pro.
Article ID: 000035022
Software:
  • ArcGIS Pro
  • Portal for ArcGIS
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
