ERROR
ConfigurationFactoryOP creation failed
Error Message
If, for any reason, the user manually changes the 'Log On As' account of the 'ArcGIS Server Object Manager' service from the default 'ArcGISSOM' account to something else in Administrative Tools > Services, user may still be able to publish map services, but when publishing any model as geoprocessing service to ArcGIS server, an error message:
"ConfigurationFactoryOP creation failed"
is logged and the geoprocessing service is empty.
Cause
The 'ArcGIS Server Object Manager' service needs to be run as the 'ArcGISSOM' account and we should not change this.
Solution or Workaround
Change the 'ArcGIS Server Object Manager' service's 'Log On As' account back to 'ArcGISSOM' and restart this service.
  1. Go to Administrative tools > Services, right-click on 'ArcGIS Server Object Manager' service and select 'Properties'.
  2. Go to the Log On tab, change 'This account' to .\ArcGISSOM and provide the correct password. Click Apply and OK.
  3. Restart ArcGIS Server Object Manager service.
Article ID: 000009812
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
