PROBLEM
Compute Camera Model fails with error (Failed to compute adjustment using engine 'Frame') when processing thermal data
Last Published: November 24, 2025
ArcGIS Pro 3.6.0 and Drone2Map 2025.2.0 fail to adjust the image collection (Compute Camera Model) when using a thermal dataset. The processing log in both software shows the following message during the Adjust Images process.
Error:
Failed to compute adjustment using engine 'Frame'.
This issue is not triggered by a specific thermal camera model, but rather by the dataset's configuration (overlap, sidelap, subject, etc.).
Cause
The Esri aerial triangulation engine received an update in the latest release, which affects the bundle adjustment process for the affected thermal dataset.
Solution or Workaround
There are no workarounds available in ArcGIS Pro 3.6.0 and Drone2Map 2025.2.0. If a thermal dataset is presenting this error, it is recommended to install the previous working version (ArcGIS Pro 3.5.5 or Drone2Map 2025.1.1). No workarounds have been found for the affected engine to adjust the thermal dataset.
Image Adjustment process is expected to be fixed in the first available patch (ArcGIS Pro 3.6.1 and Drone2Map 2025.2.1)
Article ID: 000039115
Software:
  • ArcGIS Pro
  • ArcGIS Drone2Map
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
