PROBLEM
Complex polygons, such as ZIP code boundaries, do not render completely in Insights for ArcGIS 3.0 under the following scenarios:
or,
The datasets can still be used to perform non-spatial analysis, such as to create charts and tables.
This issue occurs when ArcGIS Data Store 10.5.12 or 10.6 is used with a PostgreSQL database version 9.6 or later. The issue causes the memory in the Data Store to become corrupted if there are either too many features or complex geometries.
Update ArcGIS Data Store to version 10.6.1. For more information, see the web help topic Upgrade ArcGIS Data Store. If using ArcGIS Data Store 10.5.1, make sure to use PostgreSQL 9.3.12 (the default installation). Also, try filtering the dataset to reduce its geometry size, or choose a generalized dataset with less complexity.
Article ID: 000019083
Get help from ArcGIS experts
Start chatting now
