PROBLEM
Color-coded layers created with online data do not work as input for benchmark comparisons
First Published: November 7, 2025
Last Published: November 17, 2025
Color-coded layers are intended for display and mapping purposes only, and are not supported as input in benchmark comparisons.
Cause
Reuse of online data accessed through ArcGIS GeoEnrichment Services is prohibited according to the Esri Master Agreement, Products and Services (E204).
Solution or Workaround
To create a layer for use in benchmark comparisons, you can generate a layer of standard geographies or hexagons, or, if you have access to a local dataset, use the Add Business Analyst Data utility to create a data layer.
Article ID: 000038964
Software:
  • ArcGIS Business Analyst Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
