HOW TO
Clip an Esri Basemap in ArcGIS Enterprise Portal Map Viewer
Last Published: May 5, 2025
Summary
The steps provided describe how to clip the basemap in Map Viewer to an area of interest (AOI) boundary layer in Portal for ArcGIS.
Procedure
  1. Publish a vector layer (area of interest) as a web feature layer to an ArcGIS Enterprise portal.
  2. Log in to the ArcGIS Enterprise portal and open the published web feature layer in Map Viewer.
opening the feature layer map viewer
  1. Open the layer properties and in the Properties pane, choose the Destination Atop blending under the Appearance section, and close the blending pane.
editing the layer appearance
  1. Under Symbology, click Edit layer style.
editing the layer style
  1. Click Style options.
selecting a symbol style
  1. Edit Symbol style.
editing the symbol style
  1. Under Solid fill, choose any fill color and set a Fill transparency value to 0, and click Done. Save it as a web map
setting the fill transparency
After clipping, some of the basemaps contain labels for the entire world extent (outside the AOI, as seen in the image below). This is because it contains a reference layer that includes reference labels for the entire world extent. To see the label only for the area of interest, reposition it by moving the layer from under the 'Reference' section to the 'Base' section.
Steps to reposition the reference layer
  1. Click the Basemap icon in the Contents toolbar.
selecting the basemap
  1. Click the Current basemap option.
selecting the current map
  1. Move the layer located under the Reference section to the Base section by dragging it.
moving the layer
  1. After moving the layer from the Reference section to the Base section, the map appears as shown below. The basemap is now clipped for the area of interest.
the clipped map
Article ID: 000034818
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
