PROBLEM
The Clip tool for raster datasets appears to produce incorrect results, the tool's dialog box reports an error when coordinate values for spatial extent are manually entered.
This issue is generally experienced when the extent values specified for the clip are based on a different coordinate system than that of the raster dataset. For example, the coordinates were obtained from the data frame's display, which may use a different spatial reference than the raster dataset.
Article ID: 000010534
Get help from ArcGIS experts
Download the Esri Support App
