HOW TO
Check if the Oracle extproc is set up correctly for direct ST_GEOMETRY SQL queries
First Published: May 5, 2016
Summary
This article describes one method of validating the setup and configuration of the Oracle extproc to be able to use ST_GEOMETRY through direct SQL queries.
Procedure
Run the following SQL query:
select sde.ST_AsText(SDE.ST_Geometry('POINT (10 10)', 0)) from dual;
This should return:
SQL> select sde.ST_AsText(SDE.ST_Geometry('POINT (10 10)', 0)) from dual;
SDE.ST_ASTEXT(SDE.ST_GEOMETRY('POINT(1010)',0))
POINT  ( 10.00000000 10.00000000)
If the extproc is not set up correctly an error is displayed. One potential error may be something like the following:
ERROR:
ORA-06520: PL/SQL: Error loading external library
ORA-06522: Unable to load DLL
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 0
ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 68
Article ID: 000011293
Software:
  • Legacy Products
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
